Floppy Mirror
Old Jan 28, 2002 | 03:54 PM
Jeff Wilson's Avatar
Jeff Wilson
Default Floppy Mirror
Hey Now All!
When I parked my baby last night, all was fine, but as I'm riding to work this AM I noticed the drivers side mirror isn't in the correct position. So I rolled down the window and try and lock it back in place, NO Luck! The damn thing just flops aroound.
I called my tech at the GM place and he said he'd probabally have to replace the whole mirror!?! :eek: WTF?!? He said none of his C5's (he works on all the C5's in town) have had this problem yet, but he had worked on quite a few S-10's and that was the case.
I'd have to buy a whole new mirror, have it painted and then he'd install it. He said between $250-300 when it's all said and done! :mad Is this right?
Is there anything else I can do?
Old Jan 28, 2002 | 05:05 PM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Floppy Mirror (Jeff Wilson)
There is a fix that involves screwing the pieces together. My GM dealer gave me an estimate of $315 for a new mirror and paint. I used the screw method and have had zero problems. This fix took maybe 30 minutes. Had trouble getting the pilot hole drilled at first but well worth the time. Do a search on the archieved topics with mirror in the title.
Every "common" problem that C5's have, I have had it. Mirror break, column lock, battery, fuel sending unit, tire sensors, etc. but still LOVE this car.
Old Jan 28, 2002 | 10:47 PM
C54TIM's Avatar
C54TIM
Yeap, that's a problem. I've gone thru four right mirrors and one left!
If you don't want to buy a new mirror?
I did a power point slide on how to fix it! If you have a power point I can send you the file! It's big file. But the job is easy to do!
Tim
Old Jan 28, 2002 | 11:06 PM
Jeff Wilson
Default Re: Floppy Mirror (C54TIM)
Tim
Tim, I'd really appreciate the powerpoint on the fix.....is it in the Tech Tips section?
Old Feb 4, 2002 | 10:47 AM
Jeff Wilson
Tim
Just a follow-up.....Tim sent the the Power Point and yesterday I did the fix.....the PPT was well layed out and very well written. I was done in under an hour!
Thanks Tim!
Old Feb 4, 2002 | 10:51 AM
Patches's Avatar
Patches
Way to go, Tim & Jeff! :cheers:
Maybe Tim can make that PP file available to the forum. This seems to be a fairly common problem.
Ed
Old Feb 4, 2002 | 12:53 PM
Garceeya's Avatar
Garceeya
Default Re: Floppy Mirror (Patches)
Ed
I second that. If we get a third then maybe we can get it posted to the tech tips. I have the same problem.
To Floppy Mirror
