Headlight motor won't stop buzzing!
Old Mar 20, 2009 | 10:40 PM
johnfrit's Avatar
johnfrit
4th Gear
Default Headlight motor won't stop buzzing!
I just bought a 2003 50th Anniversary Roadster with only 26K miles on it. I checked everything out before I bought it, and it all worked. When I got home the headlight come on ok but when I shut them off they close but there is a loud buzzing coming from I think the right hand light. Is there a shut off relay that is out of adjustment and if so where?
Old Mar 21, 2009 | 12:45 AM
intoc6s's Avatar
intoc6s
Sounds like the plastic gears that raise/lower the light assembly are worn out. Pretty easy fix. But u gotta take your headlight motor apart and install a new gear. Might want to upgrade to a brass(i think its brass, its metal i know) gear. Look at the sticky at the top- Weights Measures etc. It has info on this! -Jason
Old Mar 21, 2009 | 12:52 AM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
I just purchased a C5 and experienced the same thing.
I haven't fixed mine yet, but I'm almost certain it is a worn gear. My '89 did the same thing. Those gears just don't last long.
Old Mar 21, 2009 | 08:41 AM
MagRedConv's Avatar
MagRedConv
It's the gear. Check out the Ultimate DIY sticky.
Old Mar 21, 2009 | 10:56 AM
johnfrit's Avatar
johnfrit
4th Gear
Default Thanks
Thanks guys I will look at it today!
To Headlight motor won't stop buzzing!
