3.42 gears
Old Jan 28, 2002 | 06:19 PM
GLENN43's Avatar
GLENN43
Default 3.42 gears
I just recived some 3.42 gears that I got used how do I tell if they are 3.42 and not 2.73 or 3.15. The guy who I got them from seamed like a up front good guy .Just checking because of all the problem there has been in the last couple of weeks on the net
Glenn :rolleyes: :flag :blueangel: :chevy :flag
Old Jan 28, 2002 | 06:20 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: 3.42 gears (GLENN43)
Ha, they better be 3.42s!
Old Jan 28, 2002 | 06:40 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
In the seriel Number:
1st part of serial number
a = 2.73
b = 3.42
c = 3.15
g = 3.42 (Z06 shot peened unit)
2nd place in seriel number:
month built
3rd place = year built
Also,
On top of a 2.73 casing there will be the letter 'A' about 1 inch tall
On top of the other casings there will be a letter 'B' about 1 inch tall
Old Jan 28, 2002 | 07:25 PM
GLENN43's Avatar
GLENN43
Default Re: 3.42 gears (kewlbrz)
Thank You they are clearly mark on a sticker Gertac 3.42 the serial BJM00764 . I had a good feeling about this man but with all the nonsence on the net I had to check
Old Jan 28, 2002 | 07:45 PM
Mike Mercury's Avatar
Mike Mercury
Glenn, if the 3.42 is for an A4; you'll be pleasantly surprised :)
[Modified by Mike Mercury, 6:47 PM 1/28/2002]
Old Jan 28, 2002 | 09:13 PM
GLENN43's Avatar
GLENN43
Default Re: 3.42 gears (Mike Mercury)
Mike
It is for an A4 . I am also having a ProTrque 2400,Transgo shift kit, PowerLoader And I can not wait (have to save a little money)
Glenn
Old Jan 28, 2002 | 11:30 PM
BluVette's Avatar
BluVette
Save some money for tires :cheers: you will be roasting your old tires soon :)
Old Jan 28, 2002 | 11:45 PM
sunvet's Avatar
sunvet
Default Re: 3.42 gears (BluVette)
Turn the input shaft just shy of 3.5 turns, the output should turn exactly once.
To 3.42 gears
