Driveline coupler, stock rubber,poly, solid, HELP!! PROS CONS
Old Mar 22, 2009 | 09:54 AM
K RIPPER's Avatar
K RIPPER
Default Driveline coupler, stock rubber,poly, solid, HELP!! PROS CONS
NOISE IN DRIVETRAIN car coming apart suspect couplers maybe bad want to have on hand couplers .Totally confused by choices know they're pros & cons W/stock, poly, solid and combos of solid/poly.If anybody has any experience,knowledge or can point me in the right direction car in question 03 Z/06 390 RWHP minor bolt ons had occaisional wheel hop suspect that caused damage working on that also any suggestions on that PLEASE chime in
Old Mar 22, 2009 | 11:07 AM
Kurtomac's Avatar
Kurtomac
If you need one I have a stock GM one for 75 shipped...they cost 150 from GM it was perfect when i took it out....pics if you want it, or you can find my thread in the for sale section
Old Mar 22, 2009 | 07:23 PM
waddisme's Avatar
waddisme
I went with rubber in front and al in rear. Pretty much std from rr section. I only changed mine because I was doing the clutch and am hoping it won't be back out for a while. Recommended not to do al for front and rear as it doesn't allow enough flex. Good luck.
Old Mar 23, 2009 | 08:23 PM
lionelhutz's Avatar
lionelhutz
I would seriously consider getting 2 aluminum ones and some shim washers. Shim the bolts on the couplers until the shaft turns true. If you get a rubber coupler make sure it looks like the GM one and is the same hard rubber as the GM one.
Peter
To Driveline coupler, stock rubber,poly, solid, HELP!! PROS CONS
