It drove fine earlier, but after starting it up 20 minutes later the car would die after putting it in drive/reverse and gassing for 2 seconds. It would also occur when the car would move forward using no gas pedal.
The car idles fine and will stay on while in drive if the car does not move.
I happen to know that this battery is on its way out (cars been sitting for awhile and has a known battery issue). Can i assume, and just replace the battery to get the BCM signals communicating?
