Z06 muffler cleanup and installation
Old Mar 23, 2009 | 10:04 PM
Wheelyneat's Avatar
Wheelyneat
Default Z06 muffler cleanup and installation
I just scored a set of slightly used Z06 mufflers on eBay. I'm not planning on a serious polish job, but can anyone recommend a good way to clean and lightly polish the titanium mufflers and pipes prior to the installation? I've read a few locked threads about installing these -- it sounds like I'm going to have to find a shop with a lift rather than risk jacking it to the necessary height. Other than dropping the rear sway bar, is there anything else I need to know? Are there gaskets at the pipe flanges I need to get from the dealer, or possibly new rubber mounts or hangers at the rear? Thanks for your input
Old Mar 24, 2009 | 12:46 AM
white90conv's Avatar
white90conv
I paid about $75 to have a muffler shop install them and I helped. If you have an auto transmission, there is a heat shield on the right which should be removed. If there were gaskets, it was no problem to reuse them.
Old Mar 24, 2009 | 12:48 AM
lucky131969's Avatar
lucky131969
polishing is a waste of time.....unless you never start the car
Old Mar 24, 2009 | 06:22 AM
Wheelyneat's Avatar
Wheelyneat
Agreed - I realize that titanium discolors with heat... maybe "polish" is the wrong word. I'm thinking more about just getting them clean and presentable while they are off the car, since I know I'll never be able to spruce them up once they are on the car.
Old Mar 24, 2009 | 02:04 PM
Jims79's Avatar
Jims79
I cleaned my Ti's up w/my BBQ grill brush, the mufflers turned out nice and clean w/a little shine. (then I replaced the brush before my wife got home) installing is a do it yourself. the back of the car has to be about 2 1/2 feet off the ground. if you don't know anyone w/a lift or have good jack stands (like 5 ton jack stands, 2 or 3 ton will not get the *** end up as high). if you will not be able to get the car high enough off the ground you may need to take it to a garage. G/L
Old Mar 25, 2009 | 02:00 AM
FlyboyZR1's Avatar
FlyboyZR1
I also picked up a set of used ZO6 mufflers, and used EagleOne never-dull to clean/polish them up, it did a great job.
Old Mar 25, 2009 | 03:03 PM
Patches's Avatar
Patches
I have cleaned/polished a couple sets using a brass-bristled brush and Simple Green. Ti is very tough so this will not scratch it.
Before
After
Old Mar 26, 2009 | 12:02 AM
FlyboyZR1's Avatar
FlyboyZR1
Patches that looks amazing. Did you use the brass brush on the tips, or just the mufflers?
Old Mar 26, 2009 | 06:32 AM
Wheelyneat's Avatar
Wheelyneat
That's exactly the look I want to achieve - thanks for the tip and the pics, Patches
Old Mar 27, 2009 | 07:40 AM
Patches's Avatar
Patches
Used the brush and SG on the entire assembly - mufflers, pipes and tips.
Old Mar 27, 2009 | 10:20 AM
Chevy Guy's Avatar
Chevy Guy
I used ultra fine steel wool and WD-40 to polish my Ti exhaust. IT worked amazing and the exhaust looks like new.
Since Ti doesn't blemish and tarnish like steel, they can be made to look like new anytime.
Old Mar 27, 2009 | 07:20 PM
Novakain1970's Avatar
Novakain1970
Not for nothing, its mufflers! Polish the tips only and be done
Old Mar 27, 2009 | 07:40 PM
Patches's Avatar
Patches
Took me less than an hour total and it's a must for a car stored on a lift.
Old Mar 27, 2009 | 11:46 PM
Chevy Guy's Avatar
Chevy Guy
Originally Posted by novakain1970
not for nothing, its mufflers! Polish the tips only and be done
blasphemy!!!
Old Mar 28, 2009 | 12:51 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
WOW! Those really look great
Thanks,Matt
To Z06 muffler cleanup and installation
