Intermittent horn - not the bladder
Old Mar 24, 2009 | 08:18 AM
99 vett babycar's Avatar
99 vett babycar
Default Intermittent horn - not the bladder
My horn comes and goes , sometimes several times in a given day , but only after a restart.
For example,, I'll start the car in the mornig, try the horn and get nothing: drive somewhere, turn the car off, restart the car, the horn works.Might keep working all day or might go away after the next restart and stay "gone" for a few days, or might continue to work for a week.
Its not the bladder because when the horn is not working and I use the key fob to lock the car, I don't get the horn "chirp". More importantly, if I use the key fob to set off the panic alarm, all I hear is the relay turning on and off. So I don't think its the relay.
I went to the dealer hopeing there might be a TSB on this and all I got was that "deer caught in the headlights" look - no clue.
I've done several searches but everything I come up with relates to the bladder and I really don't think that"s the problem, nor do I think its the relay since I can hear the relay working when I hit the panic button.
Anyone have any ideas? Thanks.
Old Mar 24, 2009 | 10:50 PM
olftboy's Avatar
olftboy
Check out this thread >> http://forums.corvetteforum.com/c5-t...tion-long.html and give location G102 a checkup. My horn had similar issues and I tracked it down to this grounding block. I found the above sticky after finding my problem. I have since checked and cleaned most of the other grounding blocks.
Old Mar 24, 2009 | 11:45 PM
lucky131969's Avatar
lucky131969
Good tip. I would start by checking the resistance to ground from pin A of the horn connector.
To Intermittent horn - not the bladder
