ac delco slotted/drilled rotor question
Old Jan 29, 2002 | 01:40 AM
SHARK777's Avatar
SHARK777
Default ac delco slotted/drilled rotor question
i purchased set of ac delco slotted/drilled rotors after about
two weeks they turned rusty in a lot of areas more than the
stock c5 rotors that clean themselves up in a couple of
minutes what do yall do to make them look presentable?
any suggestions would certainly be appreciated!!!!!
Old Jan 29, 2002 | 03:53 PM
davidfarmer's Avatar
davidfarmer
Default Re: ac delco slotted/drilled rotor question (Buckmaster)
Rust is part of the game, and anyway, what it so wrong with a little rust??
I am currently running 1/2 set of the drilled rotors against and OEM unit to see if they hold up better or worse. .
Dave
Old Jan 29, 2002 | 07:34 PM
Mako's Avatar
Mako
Default Re: ac delco slotted/drilled rotor question (rappskull)
If anyone else has any experience with these rotors please let me know ASAP as mine are to be delivered on Thursday and I will return them and make another choice if they are going to look rusty all of the time. I will keep them if this is a minor problem.
Porsche brake rotors never seem to have this problem. What gives?
Does anyone have any experience with "Powerslot" rotors?
Thanks for your thoughts!
Old Jan 30, 2002 | 10:54 AM
chuckster's Avatar
chuckster
Dude, I had the same thing happen and I was pissed! Rust sucks! It belongs on Locomotive wheels not a C5!
I tokk em off along with the Caliper Brackets and had them Nickel/Zinc Plated.
Here is the link for the place in Florida I had em done. You can find a place locally to do it.
They did it for about $300 cause I had rust. But if there was no rust..$200
Plus the plating is much thicker than the Baers and such...
Look Awesome and saved a ton of $
http://forums.corvetteforum.com/zerothread?id=213903
[Modified by chuckster, 8:56 AM 1/30/2002]
Old Jan 30, 2002 | 02:59 PM
Mako's Avatar
Mako
Default Re: ac delco slotted/drilled rotor question (chuckster)
I decided to send them back and go with Powerslot rotors instead--slotted but not drilled. Glad I saw this thread!
To ac delco slotted/drilled rotor question
