multidisc torque converter idle question
Old Mar 24, 2009 | 10:40 PM
12leavu's Avatar
12leavu
Default multidisc torque converter idle question
i upgraded to a multidisc torque converter. has anyone else here done this. if so did you have to raise your idle in you tune. if so how much?
Old Mar 25, 2009 | 11:17 AM
corvettebob1's Avatar
corvettebob1
1. Yes
2. Why would you?
Old Mar 25, 2009 | 11:42 AM
12leavu's Avatar
12leavu
Originally Posted by corvettebob1
1. Yes
2. Why would you?
because the people at precision industries said i needed to. i upgraded to multidisc and now when i put it into reverse or drive it goes dead until car is warmed up. this was not a problem before the converter upgrade. thanks
Old Mar 25, 2009 | 04:41 PM
12leavu's Avatar
12leavu
i copied the idle and idle airflow tables from a friend with a multidisc. it has improved. it just bogs a little now and hunts idle for a second when placed in gear , but it doesnt go dead anymore. just a little more tweaking i guess.
Old Mar 26, 2009 | 10:51 AM
corvettebob1
Really, that's kind of interesting.
I'm not a tuner but I would think since our cars are drive by wire and the PCM controls the idle speed, 600 rpm would be just that no matter what converter is in the car.
Were any other changes made to the car, like a cam?
Old Mar 26, 2009 | 11:16 AM
black98c5's Avatar
black98c5
The car should not be doing that just because of the convertor. I can understand if you have a big cam and it's not tuned...
Old Mar 26, 2009 | 09:04 PM
12leavu's Avatar
12leavu
402 with huge cam. im not a tuner either, but i have hp tuners and can play around with a few things. my tune and car has been fine. i changed to a multidisc from a single disc vigilanti converter. when i got the converter back, it doesnt wanna stay running when i put it gear. i talked with precision industries and my tuner. they both said that some changes may need to be made. the new converter is putting more of a strain on the car at idle, because the clutch discs are tighter than the single disc converter. ive got it running better now with the changes i made. my tuner said he can get it worked out when he gets back in town. thanks
Old Mar 26, 2009 | 09:41 PM
TheCartel's Avatar
TheCartel
Yes.
Yes you will need to make some changes. A single disk is much "looser" than a multi. I run one as well, but I'm going with a blower very soon.
Old Mar 27, 2009 | 11:21 PM
Bad97ta's Avatar
Bad97ta
my car did that when i changed converters. i raised the idle and now no problems.
To multidisc torque converter idle question
