AT Cooler
1. Would like to know what is best,
and
2. does the top or bottom line now connected to the radiator return to the tranny.
3. Should I fill it with fluid and then install it?
and 4. Is there a lot of fluid loss when you undo the existing lines?
Thanks in advance.
Jim
I think how you install the cooler depends on the weather you're going to be in. There IS a such thing as *too cold* for a transmission, so if you're going to be driving it in any kind of winterish conditions, definitely have it run through the radiator as well.
If its a nice-weather only car, you should be fine installing it as a standalone.
On my truck, I definitely had it run through the radiator (I think I had it to the aftermarket cooler first and then through the radiator as this doesn't let the fluid get too cold in winter..). Not sure what I'll do on the vette yet.. probably the same way since I'm sure I'll be driving the car up until snow falls.
I’d spend more time on selecting a cooler, get a plate style cooler they are designed for oil/trans cooling. A tube and fin will not cool the trans fluid nearly enough. Also, be sure to get the appropriate size. If you race you may need a 11x11 sized cooer, if you don’t then one half that size is fine.
I'm pretty sure the top is the return line. I think the philosophy is to fill from the bottom so air pockets are less likely. Do the same on your secondary cooler.
The routing of the lines is another area of PIA. A hint is you can go under the radiator.
If you are like me, yes you will loose a lot of fluid. Or at least it will look that way, and pre-filling would only add to the mess. But, then again I can make a mess with just about anything. It is not a huge amount…
