HID headlamps
Old Mar 26, 2009 | 10:32 AM
corvette4life's Avatar
corvette4life
Default HID headlamps
Where can I buy them?
Thanks,
Kerry
Old Mar 26, 2009 | 10:59 AM
RAL04VETTE's Avatar
RAL04VETTE
Just Google 'HID HEADLIGHTS' and you'll get plenty of places to choose from. Bulb type 9006 for low beam and 9005 for high beam (I think it's the same for all C5s.
Old Mar 26, 2009 | 11:45 AM
black98c5's Avatar
black98c5
Thanks,
Kerry
Here you go: http://forums.corvetteforum.com/c5-g...-motoring.html
Old Mar 26, 2009 | 12:03 PM
Lear31A's Avatar
Lear31A
I recently replaced my fogs,hi's and low's. The lights are really bright but the drivers side shines ALOT lower and to the right than the passenger side. I have read that this is built into the design of the corvette headlights. I only replaced the bulbs and did not adjust the lights at all. It really is irritating and I may put the original bulbs back into the low beams. Does anyone know a fix for this. If I adjust it up, then the driverside hi beam will be shining into the treetops.
Old Mar 27, 2009 | 11:47 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I replaced mine with HID and if you have one that is really low I would check and make sure the bulb is seated correctly, It took me 3 trys to get the bulb in the right way, I am willing to bet this is your prob... Both of mine are the same with no adjustment at all.
Bill K
Old Mar 27, 2009 | 04:37 PM
rcs128's Avatar
rcs128
Bill K
Me too -- it took forever to get one of the blubs to seat correctly. Not sure why; normally I'm a pretty competent mechanic.
Old Mar 27, 2009 | 05:20 PM
AviatorVette's Avatar
AviatorVette
i got 8000 K onex hid's they rock.
Old Mar 27, 2009 | 09:23 PM
lionelhutz's Avatar
lionelhutz
Double check that low beam lamp is installed in the headlight correctly. If you have it a little off it could be in on an angle which would throw the light beam off.
Peter
Old Mar 27, 2009 | 10:32 PM
Lear31A's Avatar
Lear31A
Thanks guys very much, I will check it out!
Old Mar 28, 2009 | 10:35 PM
Lear31A's Avatar
Lear31A
Peter
Thanks guys, tonight I pulled up closely to the garage door and fidled with it until it seated properly. When it seated the headlights matched perfectly! I guess thats why we should continually research and not take "one" thread as gospel. I read that it was designed ionto the corvette that way. Man, I was soo close to getting rid of these lights, they are awesome, thanks again.......
Old Mar 28, 2009 | 10:42 PM
Mr.Bill's Avatar
Mr.Bill
Glad you got it, You will like the lights, I did both highs and lows and did the relay mod where both lows and highs are on when you go to high beams.
To HID headlamps
