I noticed a lot of the members install this. What does it do? Is it worth installing? I'm guessing it increases HP. Once installed, is there a big difference when you step on the gas pedal? Thanks in advance.
It also allows the engine to breath the cooler air from outside instead of the hot air in the engine compartment. It has been said to increase power by up to 15hp. I noticed a slight difference in feel when I did it myself. :cheers:
Definately one of the best mods you can do. 15-20hp for only $250, can't beat that! This, and an exhaust system are the first mods people usually start out with. :cheers:
