So I'm considering changing out my transmission fluid for Royal Purple Synchromax. I'm up to 80,000 miles and I have no clue if it's ever been changed. My shifts feel very "stiff" so I'm hoping to improve on it. However, I have a '99 and am concerned about damaging the "paper" seals? I read this could be a problems on the older models ('98-'00). Will the Synchromax cause any problems on my '99?
Also, any good writeups on how to change the fluid?
I don't know much about the '99 gaskets but I remember reading about it somewhere - a search of the forum should give you the info.
What I do know is that my '00 A4 was flushed with Amsoil ATF a few years ago. I was all excited b/c the tranny was rebuilt (a little) and I had fresh new synthetic. The problem was that after the flush, the shifts were hard. I was a little miffed b/c another tranny shop did this to another car of mine a few years back as a "performance tune" and I figured this time they did the same thing to the vette. Not so. After about a year, I flushed out the Amsoil in the tranny with regular, non-synthetic, ATF and the shift points were back to being smooth.
I don't know about the ATF you are considering but if the viscosity is thicker than the standard stuff, like Amsoil syn ATF was, then you might get the hard shifts.
I have a '99 FRC and went with Royal Purples synchromax. I didn't have any issues prior and still don't almost a year later.I changed all the fluids because I bought my car used and there were some unknowns. I went though the whole car just so I'd know. I read about all the paper blocker rings and ect...after all the reading I made the decision and have had no issues.
I used Mobile 1 ATF and did not have any issues. One thing to consider. If you drain and fill - you only get about 4 quarts of the 14 or so quarts in the system. You can't drain the torque converter or the coolant lines and cooler. I purchased 15 quarts (took the extra back) and took to the local chevy dealer quick service center and had them do a complete flush with my fluid. Cost was $75.00 for the service plus the fluid (yea it was expensive over just 4 quarts of fluid). Now I have all synthetic in there. And since you only change it every 100,000 miles, figured it was worth the extra.
SynchroMax in an A4? Think about that for a minute.
I know one of the sponsors told me to use the cheap Advance Auto parts ATF in mine. I did in their level 5 tranny with no issues. It isn't synthetic either. I have Amsoil in it now and have installed Amsoil in a few of the 97-2000 vettes with no issues.
Just want to make sure the Royal Purple Synchromax won't do any damage on a '99 (paper blockers).
Alternately, I've been hearing the Amsoil brand is okay for paper blockers... any advice on either of the two brands?
Just off the top of my head, remembering from when I was researching..I think the Royal Purple ATF was the one in question when it came to the paper blocker rings. The Sychromax is a manual gearbox specific fluid that meets the ATF standards needed for "our" transmissions. I also have Royal Purple in the rear diff, although I do run Amsoil in the engine.
Kinda off topic but, I also have Royal Purple ATF in my F350( trans and transfer case), and their gear oil in the front and rear differentials. No issues.
Originally Posted by Steve Doten
I don't see trans builders pushing labels..................
But one of the biggest and best known here DO say to NOT use any synthetic fluid in their (6 spd) transmissions AT ALL. Then in the same breath, they turn around and say if you DO want use a synthetic of some kind, ONLY use Royal Purple Synchromax. I realize Synchromax is not an ATF, but why the complete and total "ban" on any (synthetic) Dexron III rated ATF?
Ummm..........WTF?? Puzzle me that one.
Reason: error correction
I've used RP for 16,000 miles with 5 trips to test and tune and 13 dyno pulls,,,,NO PROBLEM!! There used to be a sticky that had the info that RP was safe for the "paper blockers",which mine has as well.Relax and enjoy,,I was very satisfied with the drain and fill with RP!!
ANY fluid that meets GM specs will work. I used O'Reilly. Got the pump at Harborfreight for five bucks. Changed the fluid at 84,000. It was grating going into sixth if shifted rapidly into sixth at relatively low vehicle speed. Filled the tranny, took the car to a local office complex on a weekend with empty parking lot, did a couple dozen tight figure eights at gradually higher speeds to get fluid into every nook and cranny of the posi unit. Have not had a single rough shift since.
If you you have shifting issues with your 6 speed, change the fluid and drive the car a couple hundred miles before you pop for a rebuild.
This is precisely the reason I'm looking to change the fluid! So I'm glad to hear it might help. I'm having issues getting it into 1st when rolling to a stop. Then other times I'm having trouble getting into 2nd or 3rd where it only engages "half-way". It feels like it's in gear, but it's not Most of the threads I've read on RP Syncromax seem to say this will cure my problems. Let's hope so. I'll be giving it a try this weekend and will post my results!
Does anyone know what exactly the GM specs are? Is it just Dexron III or is there something more specific. Where can I find the published spec?
Originally Posted by Pineapple1
..........Does anyone know what exactly the GM specs are? Is it just Dexron III or is there something more specific. Where can I find the published spec?
In six speeds, GM says Dexron III ATF. Nothing else mentioned. It does NOT say old style (conventional petroleum based) Dexron III rated fluid OR synthetic Dexron III. There is NO prohibition OR recommendation on either one. Just says Dexron III ATF. In your OM.
Bear in mind that RP Synchromax is NOT an ATF at all. I've heard a number of good comments here over the years about it, but technically speaking, it does NOT meet "GM spec".
