Question on Clutch operation?
Old Mar 29, 2009 | 05:51 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Default Question on Clutch operation?
Driving the Z today and while in third at low Rpm i punch it, at about 5900 rpm I go to shift into fourth and the clutch is hard as hell so i back off and as i slow down it gets easier to depress the clutch, than goes back to normal. This is the first time this has happened to me? What does this mean?
Old Mar 30, 2009 | 12:31 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
It means you should start saving for a clutch most likely. That's how my problem started and progressed to a stuck pedal. Since the clutch swap I haven't had either issue. I'd say do a search and read up on the hard pedal and sticky pedal but search seems to be off these days.
Old Mar 30, 2009 | 09:11 AM
mariofromnewyork
Default Thanks ?
I searched and it seems so. Time to save!
Old Mar 30, 2009 | 01:01 PM
MattB's Avatar
MattB
In the interim I'd look at doing the 'Ranger method' and try and make the current one last a while more Just search for it, its pretty popular.
To Question on Clutch operation?
