Oil Change from Hell
Old Mar 29, 2009 | 07:08 PM
sgm2004's Avatar
sgm2004
Default Oil Change from Hell
ALCON, just a tread about my first C5 oil change today. Got her jacked up (Dam thats a low car) (but I like it). Came time to remove the drain pug and it would not move. I tried every thing short of diamite. When I finally believe it or not brought out the impac drill. Talk about sweating one. After about three hits if finially came loose. Man what a stressful event. I have no idea who changed it last but it must have been a shop. Needless to say the rest went well. My point make sure if you get some shop to change your oil for you. That he doesn't use a air impac thats presure is set to mount lug nuts. Only 18 PSI is all you need. Take care
sgm2004
Old Mar 29, 2009 | 07:11 PM
timemender's Avatar
timemender
Count your blessings it was not stripped or cross-threaded.
Old Mar 29, 2009 | 07:21 PM
Patches's Avatar
Patches
You're lucky - I did the first oil change in the wife's '02 the other day and there was already a helicoil in there. Apparently, the PO had the dealership stooges do his oil changes and they went the extra mile with their impact tools. They're the same guys who overinflated the snot out of the tires so that the TPS monitors went nuts a few miles after I picked up the car when we bought it.
Old Mar 29, 2009 | 07:25 PM
lucky131969's Avatar
lucky131969
Wow, thanks for sharing....that's really good advice......
Old Mar 29, 2009 | 08:07 PM
happa's Avatar
happa
Thanks for sharing, I had a couple of times that happen to me. I change my on oil and I guess I tighten to much. But ever since I got a new drain plug I havent had that problem.
Old Mar 29, 2009 | 08:45 PM
carsangelop's Avatar
carsangelop
I just snug mine up fill it with oil and let it sit for a hour or so and check for drips.If I leaks a little I just snug it up a little more I usually do it on a Saturday afternoon when I have plenty of time.
How would anyone get a impact gun on there anyway?
Old Mar 29, 2009 | 08:46 PM
csexton's Avatar
csexton
Glad it worked out
Chuck
Old Mar 29, 2009 | 09:12 PM
TEXHAWK0's Avatar
TEXHAWK0
sgm2004
I think you meant 18 ft-lbs instead of Psi, but it does not really even need to be that tight.
With the built in rubber gasket, I have always just made the plug snug with a 6 inch wrench, and have never had one come loose.
Back when cars had metal oil pans, I have seen mechanics tighten the plug so tight that they cracked the oil pan, and ended up having to replace the pan. At least you can rethread the aluminum if the threads get messed up, but who wants that? On my brother's Camaro, I ended up putting a hydraulic jack under the wrench handle and slowly using the jack to break it loose. Almost lifted the car before it came loose. Absolutely no reason for the plug to be that tight.
Old Mar 29, 2009 | 10:36 PM
BRWK's Avatar
BRWK
the dreaded.....just a little bit more.....always gets me
I hate over tightening things.
Old Mar 30, 2009 | 12:18 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Back in the day I've seen them so tight that the spot welds broke on the brace on the inside of the pan and that was the end of that. Only fix was removing the pan for a couple tack welds or pan replacement. At least with a stripped plug they sell over sized plugs.
Old Mar 30, 2009 | 11:36 AM
Steve20's Avatar
Steve20
"""I ended up putting a hydraulic jack under the wrench handle and slowly using the jack to break it loose."""
American Ingenuity at it 's finest------great idea Hawk
Steve
Old Mar 30, 2009 | 08:25 PM
sgm2004's Avatar
sgm2004
Thanks for correcting me on that one. I have these headspace and timing problems the older I get.
sgm2004
To Oil Change from Hell
