Stock C6 wheels on a C5
Old Mar 30, 2009 | 09:46 PM
mrigas21's Avatar
mrigas21
Default Stock C6 wheels on a C5
I have a 2000 coupe with stock wheels. I have access to a nice set of C6 polished wheels that are Front= 18 x 8.5 +56 offset and Rear= 19 x 10 +70 offset. Has any done this and if so how did they work, rub, ride, etc? I checked the OD and rev per mile of the tires and they are very close to the stock sizes on my car now.
thanks
Old Mar 30, 2009 | 11:18 PM
my6thvette's Avatar
my6thvette
The worked fine on my 1999. OEM C6 rims and tires.
Old Mar 30, 2009 | 11:25 PM
TheWildcat's Avatar
TheWildcat
Default wheels
I have chrome C6 wheels on my 97... I like the look with 1" spacers on the rear... if you use your tpms, you will have to use your C5 sensors, You will need 4 gromets for the c6 sensors to make them fit the C6 wheel just right..hope that helps...John
Old Mar 31, 2009 | 09:10 AM
Mike Mercury's Avatar
Mike Mercury
front C6 rims are the same exact offset as front C5 rims. Direct bolt on with no issues.
Rear C6 rims have a different offset than factory C5 rear rims... the C6 rims will sit slightly inward.
Seems 50% of those doing this swap experience slight rear tire rub against the inner fenderwell. When I did this upgrade, the rear tires were close - but not touching. I still went with 1/4" plate spacers on the rears - solely for cosmetic reasons.
Old Mar 31, 2009 | 10:03 AM
VETFEVER's Avatar
VETFEVER
Exactly as Mike said....I did not need spacers on the rear - no rubbing - but a set of 1/4 inch spacers are pretty cheap and the look on the C5 is great...
Good luck
To Stock C6 wheels on a C5
