Oil Sensor Replacement
Old Mar 30, 2009 | 09:47 PM
James Kinne's Avatar
James Kinne
Default Oil Sensor Replacement
Looking for procedures in the replacement of the sensor. This is the 1st for me. Any clues. I read about the relocation. Need more info re; intake manifold R&R, etc. Thanks for any guidance available.
Old Mar 30, 2009 | 10:18 PM
Markham's Avatar
Markham
Default The best writeup.
This one is the best.
http://forums.corvetteforum.com/c5-t...y-vectorz.html
I just did it last weekend and the instructions are detailed.
Your year might vary slightly for the fuel lines.
I hope this helps.
Old Mar 30, 2009 | 10:46 PM
jrprich's Avatar
jrprich
Look at the sticky in C5 Tech
http://forums.corvetteforum.com/c5-t...-relocate.html
Old Mar 31, 2009 | 09:26 AM
Fast Cop's Avatar
Fast Cop
Just did mine while I was doing header install. Very easy DIY. I used this link:
Old Mar 31, 2009 | 02:45 PM
dancin1's Avatar
dancin1
While you're in there, why not relolcate it to under the drivers side FRC. That way, next time you need to replace it it'l be a 5 minute job, and with the slightly less vibration and heat in that new position it might be quite awhile.
To Oil Sensor Replacement
