Clutch Fluid Replacement
Old Mar 31, 2009 | 12:23 AM
Boulty1961's Avatar
Boulty1961
Default Clutch Fluid Replacement
After doing a search I found lots of information on clutch fluid replacement.
I have attached Rangers Post on this subject.
(Thanks to Ranger for good information and post)
This is what was left after the black fluid was removed.
Long story made short... Don't let this happen to you.
Yes it was that bad!
Get it all out.
Refill, Drive, Repeat, Repeat, Repeat......
Here is the post by Ranger:
http://www.rangeracceleration.com/Clutch_Care.html
I will not let the fluid get this bad again.
The clutch is working much better now.
Old Mar 31, 2009 | 01:07 AM
Dennis Wilson's Avatar
Dennis Wilson
I do it about once a month, never had a prob. with clutch!
Old Mar 31, 2009 | 10:51 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Yea I like to keep up with mine also... If mine is not clear they I like to cycle some new stuff in there.
I have never seen mine as dirty as yours. Good gob catching it before something really failed on you.
Toque
To Clutch Fluid Replacement
