help - having heat issues
Old Mar 31, 2009 | 01:32 AM
lazya's Avatar
lazya
Cruising
Default help - having heat issues
I have a 1998 with electronic hvac controls-I am having a problem with my hvac- passenger heat settings work fine if I manually adjust the temperature on the passenger side. The drivers side when i set it to 60 which is the lowest everything is fine, blows really cold & i can switch it from face to floor etc. If I set it to 65 on a warm day it will act as if it was set to max. temperature. If I back it down to 61 then it will cool down & as the car warms up it wil start to act normally if I crank it up only 1 degree at a time. Any help would be much appreciated
Old Apr 1, 2009 | 10:30 PM
Boulty1961's Avatar
Boulty1961
Have you checked the codes?
Codes For C5 Corvette
http://www.stengel.net/diccodes.htm
I think that you will have HVAC B0361 and maybe B0441 also. If this is the case there is a good bit of information with pictures on the forum to help you.
