Um.. yes. That's way more than you need at idle. My 03Z with a ported and shimmed stock pump makes about 45psi at idle with 5W 30 Royal Purple at operating temp.
did alot of reading and it seems a lot of engine builders are using 15 50 in supercharged setups ....since my kit uses engine oil to cool the supercharger my oil temps run a little higher than most
I can't speak for SC setups, but the rest of the engine was designed for 5W30, not the heavier oils. Just a concern on my part that's all. You do as you wish with your engine.
