I dropped my car off at the shop to have headers, pipe, intake manifold, throttle body installed & when i picked it up my right hand side running lights/ turn signal was not working. the shop told me it was the bulb but its odd b/c when the ignition is on the lights work (the turn signal still doesnt flash), however as soon as the engine starts they do not. i dont understand why they will only not work when the car is on, and will light up when just the lights are. i really appreciate any help.
There is something wrong with the way you explained that. Park lamp filiment is different from DRL filiment. I would change the bulb if I were you, it only cost $2, if that dosn't fix it, post again and explain it a little better.
I replaced the side bulb but then realized the original lit up just fine when the ignition was on. The DRL don't work EXCEPT only when the ignition is turned on & the lights are turned on.. without the engine. as soon as i start the car they turn off. I see the lights are functioning and yet don't any time except when the headlights are turned on and the engine is turned off. i apologize if this is confusing but thats the best i can explain it. again thank you for any help!
