air pump
Old Apr 4, 2009 | 05:09 PM
lysy_222's Avatar
lysy_222
Default air pump
Hi
Another problem with the pump does not work when connected. Checked the cables in order up to the pump and, as it proves there is no red wire is not current. Cable has a fuse switch, it is good. The relay is operating. I do not know where should I look for reasons why.
Whether the pump is working right after the ignition??
regards
