Installed Hotchkis Sway Bars
Old Apr 4, 2009 | 07:49 PM
Sinister-one's Avatar
Sinister-one
Default Installed Hotchkis Sway Bars
Just got through installing a used set of Hotchkis Sway Bars.
MAN, WHAT A DIFFERENCE !!!
The car takes corners like it glued to the road !
I've purchased a new set of Bilsteins on fleabay and should be here next week. That should make a heck of a difference as well.
I any of you are looking to do this swap, I highly recommend it.
Old Apr 5, 2009 | 11:54 AM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
Did the same a few years ago, but used c6 z06 shocks. GRT
Old Apr 5, 2009 | 12:27 PM
molson's Avatar
molson
I did this last year
Make sure you get the metal endlinks if you don't already have them
Old Apr 5, 2009 | 12:59 PM
happa's Avatar
happa
I had added Bilstiens and it made a world of differance. I really want some sway bars now. I cant imagine it handling any better. Congrats on the sway bars, very nice
Old Apr 5, 2009 | 01:36 PM
vmaquera's Avatar
vmaquera
Ditto!!
Bilstein Sports, Hotchkiss Sway bars, 325/19 Goodyear Supercars...........My "Midnight" rides stiffer (I like it), handles like as if it were on rails.
Old Apr 5, 2009 | 01:38 PM
Sinister-one
The bars came with the metal end links from Hotchkis.
DAMN these are some bada$$ sway bars !! There is no body lean when taking the corvers....
Old Apr 5, 2009 | 01:40 PM
Sinister-one
Oh it does handle 1000 times better !
Can't wait to get the Bilsteins on next weekend.
Old Apr 5, 2009 | 05:03 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Have the same ones and there great!
Old Apr 5, 2009 | 06:51 PM
ALLEGRO's Avatar
ALLEGRO
What about ride quality? I have the F55, any knowledge on how it affects that?
Thanks ahead.
Old Apr 5, 2009 | 09:13 PM
Last C5's Avatar
Last C5
Thanks ahead.
Sway bars don't affect ride except when cornering and even then only amount of is lean is affected.
Old Apr 5, 2009 | 10:45 PM
Bad97ta's Avatar
Bad97ta
i just added the very same setup. swaybars and shocks with sim sensors.
lets just say when you look at the new bars and sit them next to the stock ones....... well its just amazing.
the performance is well worth the money. but i find myself trying to speed through turns to see how amazing it holds the road. and i just cant stop smiling
Old Apr 5, 2009 | 11:03 PM
Sinister-one
and I can stop smiling either.
The Hotchkis bars are HUGE compared the Z06 bars I had on the car !
And yes the car is amazing in the turns.
Old Apr 6, 2009 | 10:27 AM
Esp0's Avatar
Esp0
I was looking into picking up a set of Hotchkis sway bars, what is the benefit to getting the metal end links as apposed to the set they sell without end links? I guess my question is, $300 extra is going to do what for me?
Old Apr 6, 2009 | 11:07 AM
Sinister-one
Hopefully you've already upgraded you plastic end links to the newer metal end links. If so, you can reuse them.
As for what EXTRA are you getting.... your car will handle "like it's on rails". If you think it take corners and turn good now, you'll see a night and day difference with the Hotchkis bars !
My car is my DD so I noticed the difference immediately.
Old Apr 6, 2009 | 11:34 AM
BitViper's Avatar
BitViper
Sways do make a HUGE diff..I went from the stock Z06 bars to T1's...its a big a leap as from the stock vette bars to Hotchicks or stock Z06 bars....its very noticeable
The only downside for the T1's is that they are a bit loud...clunks at low speeds
Old Apr 6, 2009 | 11:53 AM
Sinister-one
Yes there is a HUGE difference. <<< See I still can't sop smiling !
I installed the metal end links that came with the Hotchkis kit. Mine are the older heim joint type end links, but I haven't heard and difference. It still rides nice and quiet.
Old Apr 6, 2009 | 11:55 AM
Esp0's Avatar
Esp0
My whole suspension is stock (lowered on stock bolts), will it still make a difference or do I need to do other suspension mods? (I know little to nothing about suspension).
Thank you!
To Installed Hotchkis Sway Bars
Old Apr 6, 2009 | 12:29 PM
Sinister-one
Thank you!
After the Hotchkis bars, do what I'm doing next weekend... swap your stock shocks out from some Bilsteins !
I picked up a set off of fleabay for less that $300 bucks, shipped !
Old Apr 7, 2009 | 01:42 PM
vmaquera's Avatar
vmaquera
Thank you!
I got Bilstein sports, even before I started any "moddin". The difference was immediately noticeable (I have a Z51 suspension). After I got done "Frankensteining" my car, the last thing I did was put on the Hotchkiss sway bars. I thought about getting the Pfadt swaybars, but I figured that I was not going to de enough autocrossing to require frequent adjustments. Besides, the Hotchkiss cost about 1/2 price of the Pfadt sway bars.
Old Apr 7, 2009 | 03:25 PM
ericdwong's Avatar
ericdwong
Not entirely true- if you hit a bump with one side of the car, because of the thicker sway bar, it will cause the car to ride a little harsher because articulation of the single wheel has been limited.
Give it some time, they may start to get noisy. I had those heim joint type bars, they lasted fine for about a year, then I started getting clunking. Wound up stripping the damn hex sockets on them, had to cut them off with a sawzall . Replaced them with metal Z06 non adjustable links, so far so good/quiet!
I too run the Hotchkis bars, Z06 springs, Koni FSD shocks. same observations- much less body roll especially coming from the FE1 suspension.
