Anyone else repair EBCMs?
Old Apr 5, 2009 | 08:04 PM
Quil's Avatar
Quil
Default Anyone else repair EBCMs?
I emailed Brandon at absfixer.com several days ago about getting my module rebuilt, but never got a response back from him. Does anyone else rebuild the EBCM?
Old Apr 5, 2009 | 08:43 PM
Bill Dearborn's Avatar
Bill Dearborn
What failure do you have? Not all failures can be repaired. Usually ABSFixer can repair the relay that causes the C1214 code but codes involving other EBCM errors may not be able to be fixed. If they do have the capability to replace internal electronics they don't have the ability to test the repaired module to see if the repair actually worked.
Bill
Old Apr 5, 2009 | 09:25 PM
Z06_BluByU's Avatar
Z06_BluByU
there is some info in my thread here on the people who offer EBCM's
http://forums.corvetteforum.com/c5-t...ode-c1288.html
Old Apr 5, 2009 | 10:03 PM
Quil's Avatar
Quil
Thanks for the link, I'll take a look at it. The code I'm getting is the 1214 code.
Old Apr 5, 2009 | 10:35 PM
motogib1's Avatar
motogib1
There are some modulemasters, but in my experience, they charge twice as much. Still if you remove the EBCM your self and have them repair it, you will still be several hundred $$ ahead over having a dealer install a new one. Plus you will have an upgraded relay which is apparently what fails. This is assuming that the EBCM is at fault.
Old Apr 5, 2009 | 11:08 PM
Quil's Avatar
Quil
Anybody used these guys? Seems awfully cheap...
http://cgi.ebay.com/ebaymotors/CORVE...04155002r11922
Maybe I'll try to call Brandon at absfixer and see if I can get in touch with him that way...
Old Apr 6, 2009 | 08:35 AM
Z06_BluByU's Avatar
Z06_BluByU
WOW that is cheap!
Old Apr 6, 2009 | 09:29 AM
chaase's Avatar
chaase
St. Jude Donor '12
Keep trying Brandon. He is inexpensive and the repair works. He may be out of town or unavailable.
To Anyone else repair EBCMs?
