Run flat tire life
Old Apr 6, 2009 | 02:25 PM
Lew W's Avatar
Lew W
Default Run flat tire life
My OE G'year run flats are seven years old, seldom in the sun, greaat tread etc. Look new. Tire guy told me they are dangerous to drive on---cracks, delamination etc due to their age. What ya'll think?
Old Apr 6, 2009 | 02:56 PM
chaase's Avatar
chaase
St. Jude Donor '12
I think its BS, but that's my opinion. I have also had tire places tell me they can't patch run flats.
My run flats are over 6yrs old and I don't have a problem with them. They are going to be replaced soon because of wear.
Old Apr 6, 2009 | 03:34 PM
lucky131969's Avatar
lucky131969
How could you possibly reach that conclusion...sight unseen?
Old Apr 6, 2009 | 04:18 PM
EStreeter's Avatar
EStreeter
The rubber can dry out and crack but that is an observable condition and can be found easily through a visual inspection.
On regular tires you may see some hair line cracks in the side wall near the rim bead or between the treads. This is mostly due to flexing of the dry rubber compound. The side wall cracks can leak eventually and cause a flat. I had some low mileage tires that had great tread on another car that were about six years old; they cracked and finally leaked through the side wall.
RFs are much thicker and stiffer than non run flats - especially in the side walls. I doubt they would leak through tiny surface cracks. And if they did you would still be able to drive on them to get service. That said, if you see cracks you probably shouldn't be doing much 100+ driving.
I bought some used tires from a forum member a few years ago that looked great and had great tread. They are probably six or seven years old now and still look good - no cracks.
If they look good don't worry about it but keep an eye on them just the same. I also think that applications of tire shine products or even some motor oil on the side walls will help preserve the tires.
I oil up my boat trailer tires (side walls) when its in storage or sitting out in the sun during the season. The tires are probably 16 years old now and no cracks can be seen.
Old Apr 6, 2009 | 06:29 PM
vmaquera's Avatar
vmaquera
What kind of oil do you use?
Old Apr 6, 2009 | 06:34 PM
Bill Dearborn's Avatar
Bill Dearborn
Run flat tires can fall apart due to age. However, their reaction to that age will be different. On non-run flat tires the increased risk of blow outs means they should be replaced. With run flats the risk of blow outs actually causing a problem for the driver is much less but would increase with age.
Bill
To Run flat tire life
