Service Active Handling Message
Old Jan 30, 2002 | 08:50 PM
Richard Red Vette's Avatar
Richard Red Vette
Default Service Active Handling Message
As I Left work, today, my 2001 C5 felt as if the brakes were being applied. My DIC showed Active Handling. After approx 15 seconds the brakes seemed to release, and the DIC then read Service Active Handling. The message did not leave my DIC until I shut down the engine, and then restarted.
Has this happened to any of you and if so, what did you find to be the cause?
Richard
Old Jan 30, 2002 | 09:01 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Service Active Handling Message (Richard Red Vette)
Codes???If you have a 1288 trouble code,there is an ABS module calibration update for the 2001-2002 (yes,it has been expanded to 2002)
Old Jan 30, 2002 | 09:18 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Service Active Handling Message (Buckmaster)
The calibration is for the ABS module,has nothing to do with PCM calibration...The calibration simply eliminates a false set ABS code 1288,if that is the code stored...
To Service Active Handling Message
