How to adjust exhaust tips?
Old Apr 6, 2009 | 06:41 PM
FlyboyZR1's Avatar
FlyboyZR1
Default How to adjust exhaust tips?
I just had some ZO6 mufflers put on my car and the passenger side tips hang lower than the drivers side. There also doesn't seem to be any adjustment bolts or anything to adjust the tips.
Anyone else run into this problem? Is it possible to even out the tips?
Old Apr 6, 2009 | 06:49 PM
Stevo92z28's Avatar
Stevo92z28
One way to easily adjust them, is where the hanger bolts are(2 on each side going into frame) to add some washers to the side that is too high. Just play with it till both sides look level. That will allow you to adjust up and down, but side to side I'm not sure. Most aftermarket catbacks there is a place to adjust but not with the factory exhaust. If you have headers/aftermarket x pipe that may be the reason the catback won't line up correct.
Old Apr 6, 2009 | 07:18 PM
clemsondave's Avatar
clemsondave
Loosen all the clamps from middle of car back. Have someone hold a 2x4 under the tips to keep them level. May need to twist/turn some of the pipes. Then re-tighten clamps.
To How to adjust exhaust tips?
