low beams on PS not working?
Old Apr 8, 2009 | 03:19 PM
vinnyxgunz's Avatar
vinnyxgunz
Default low beams on PS not working?
the same bulb works on the DS... what would cause this?
Old Apr 8, 2009 | 03:39 PM
lucky131969's Avatar
lucky131969
Do the high beams work? If so, you know that the ground is intact. Start out by checking fuse #8 in the underhood fuse block
Old Apr 8, 2009 | 03:48 PM
vinnyxgunz's Avatar
vinnyxgunz
high beams work on both sides... low beams only work on drivers side
Old Apr 8, 2009 | 03:53 PM
lucky131969
ok, so check fuse 8
Old Apr 8, 2009 | 04:01 PM
vinnyxgunz's Avatar
vinnyxgunz
will do when i get home... thanks
To low beams on PS not working?
