Park Brake Self-Adjust Problem
Old Apr 28, 2009 | 01:13 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by 2A372C
I have never seen a C5 that had a true emergency brake that was capable of stopping the car from speed quickly, but they work great as a parking brake.
I believe this is because the shoe is about an inch wide and very small in diameter.
And I seriously doubt you ever will. It's not designed nor installed to function as such. It is a parking brake only.
Old Apr 28, 2009 | 08:28 PM
Atok's Avatar
Atok
Originally Posted by LoneStarFRC
Sounds good. By "adjusting them up" can we assume you mean you removed your rear wheels and calipers/rotors and adjusted the mechanism?
Yes, correct. I removed the rotors and adjusted the "star" wheels until I could feel a little drag on the rotor when re-installed. My problem is solved. The park brake is fully engaged and holds well at about 1/2 travel.
Thanks for the advice folks.
