Reverse Lockout Replacement Procedure
Old Apr 10, 2009 | 10:01 AM
95BlueBomber's Avatar
95BlueBomber
Default Reverse Lockout Replacement Procedure
Does anyone have the procedure for changing the reverse lockout on our cars? When the driveline was put in it was not plugged up. I later found that out and plugged it up. It still isnt working. I would assume its gone bad. I am kind of thinking I have to pull the tranny to replace it. If someone can give me an idea of what I am looking at it would be great. Thanks!
Old Apr 10, 2009 | 11:00 AM
timemender's Avatar
timemender
Sorry no photos - text only
Document ID# 424458
1999 Chevrolet/Geo Corvette
2000 Chevrolet/Geo Corvette
Reverse Lockout Solenoid
Removal -
Tools Required
J 41099 Gear Select/Reverse Lockout Solenoid Socket
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
1. Disconnect the negative battery cable.
2. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
3. Remove the rear tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
4. Remove the intermediate exhaust pipe to muffler bolts.
5. Tie off the mufflers to the underbody to support out of the way.
6. Remove the rear transverse spring. Refer to Rear Transverse Spring Replacement in Rear Suspension.
7. Disconnect the wiring harness and brake pipe clip retainers from the rear suspension crossmember.
8. Position a transmission jack under the rear suspension crossmember and firmly secure the crossmember to the jack.
9. Using ONLY HAND TOOLS, remove the rear suspension crossmember mounting nuts.
Important
Observe the clearance between the driveline and the driveline tunnel closeout panel.
10. Slowly lower the rear suspension crossmember, along with the attached driveline, approximately 4 cm (1½ in). (Lower the rear suspension crossmember and driveline for access to the reverse lockout solenoid.)
11. Disconnect the reverse lockout solenoid electrical connector.
12. Using the J 41099 , remove the reverse lockout solenoid.
Install –
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
1. Using the J 41099 , install the reverse lockout solenoid. Tighten
Tighten the reverse lockout solenoid to 40 N·m (30 lb ft).
2. Connect the reverse lockout solenoid electrical connector.
1. Slowly raise the rear suspension crossmember to seat to the vehicle frame rails.
2. Using ONLY HAND TOOLS, install NEW rear suspension crossmember mounting nuts. Tighten
Tighten the rear suspension crossmember mounting nuts to 110 N·m (81 lb ft).
3. Remove the transmission jack from the rear suspension crossmember.
4. Connect the wiring harness and brake pipe clip retainers to the rear suspension crossmember.
5. Install the rear transverse spring. Refer to Rear Transverse Spring Replacement in Rear Suspension.
6. Remove the tie-off retainers from the muffler assemblies.
7. Install the intermediate exhaust pipe to muffler bolts. Tighten
Tighten the intermediate exhaust pipe to muffler bolts to 50 N·m (37 lb ft).
8. Install the rear tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
9. Lower the vehicle.
10. Connect the negative battery cable. Tighten
Tighten the negative battery cable bolt to 15 N·m (11 lb ft).
11. Program the transmitters. Refer to Transmitter Programming/Synchronization in Keyless Entry.
Old Apr 10, 2009 | 11:27 AM
95BlueBomber
Do you by chance have the part number for a new one?
Thanks for all the info!
Old Apr 10, 2009 | 11:32 AM
timemender's Avatar
timemender
No part numbers in the service manual (other than tools) - at least none that I know of.
Contact forum vendor Gene Culley at GMPartsHouse.com
Old Apr 10, 2009 | 11:36 AM
byronhunter's Avatar
byronhunter
Some times a little troubleshooting saves time, money or both. Hope this helpes.
Old Apr 10, 2009 | 11:52 AM
95BlueBomber
Where is that solenoid control located? I would assume the inhibit solenoid is the one on the tranny.
Old Apr 10, 2009 | 11:55 AM
byronhunter
Solid State Circuit, inside the PCM
To Reverse Lockout Replacement Procedure
