So I picked up a Raptor Shift Light and will be installing it soon. The only installation instructions from Raptor for a C5 are:
Tach signal is at PCM, red connector (C2), pin #10, white wire Vss signal is at PCM, red connector (C2), pin # 50, dark green with white stripe wire
I haven't had reason to remove my PCM yet, so I'm looking for a guide with pictures (if one exists, that is). I would like to get a warm and fuzzy before splicing wires when my PCM is involved. Raptor has a link to the following...
