Rear Wheel Hop
Old Apr 11, 2009 | 03:30 PM
bojangles5169's Avatar
bojangles5169
Default Rear Wheel Hop
On certain pavement types I get "rear wheel hop" going to the next gear @ WOT. My '02 C5 Z06 has stock gears, 11" wide street tires and a few "warm up" mods to the engine. I'm assuming a change to the rear shocks might improve or solve the situation but I don't want to make much of a sacrifice in ride quality. I'm sure a lot of y'all have had and solved the same problem. What works best - keeping in mind that I'm a cheap skate? Oh - this is in "performance mode" as well.
Thanks for any ideas and yes I know - the gas pedal has a lot to do with it!
Bojangles5169
Old Apr 11, 2009 | 04:29 PM
clif's Avatar
clif
St. Jude Donor '09-'10
Be carefull to let off the gas if the wheels start to hop. A stock drive line will break under these extreme loads.
Old Apr 11, 2009 | 04:46 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
as far as I can tell based on various cars, 2 things that help with eliminating wheel hop are shock settings and stiffer bushings - of course tires are a factor too.
I get wheel hop in my vette - mostly in rain, which is wierd - you'd think MORE grip would cause it, not less.
On my kit car, I've had some success in tuning it out via adjustable shocks - by giving it more compression and less rebound.
Old Apr 11, 2009 | 04:52 PM
blazer427X3's Avatar
blazer427X3
I've heard people who use Bilstein Sport shocks report that its helped with the wheel hop problem somewhat.
Old Apr 11, 2009 | 08:00 PM
K RIPPER's Avatar
K RIPPER
Same problem,o3 Z/06have tried,lowering rear,single adj. QA1 shocks,PFADT trans brace all seemed to initally help and tires seem to play a large part, BFG DR very seldom 3/4 worn mich.pilot spt. bad hop I've replaced the bellhousing already if you find a cure POST IT OR PM ME thanks
Old Apr 14, 2009 | 01:29 AM
bojangles5169
Default Thanks Y'all
K Ripper you saved me some bucks - those were some things I was going to try. Mine mostly does it on newish concrete & not on black top. Guess I'll get off the loud pedal till we hear from some quarter milers. Granted I don't use a bleach box for burn outs on city streets - that may be the answer - heat 'em up 1st.
Thanks again for the responses -
bojangles5169
Old Apr 14, 2009 | 03:36 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
I was getting really bad wheel hop with my car when it was 800 HP. I installed a DTE transmission brace and it totally went away. Only my experience for what it is worth.
Old Apr 14, 2009 | 04:07 PM
sothpaw2's Avatar
sothpaw2
Drag radials or road race tires w/ a very soft compound would seem your best bet.
Old Apr 14, 2009 | 07:08 PM
TQDrivenws6's Avatar
TQDrivenws6
QFT.
I get wheel hop on my street tires, not on my DR's. Tires that stick will alleviate the problem.
Otherwise since you said it happens at the gear change just don't shift so hard, for the true 'cheap' fix.
To Rear Wheel Hop
