Cigarette lighter?
Old Apr 12, 2009 | 08:46 PM
TPA Z06's Avatar
TPA Z06
Default Cigarette lighter?
Anyone ever have any trouble with it? Seems mine let go of the sleeve that holds the lighter element, and now the piece which holds that sleeve is kind of floating around behind the fascia plate. Is it necessary to remove the whole center console to get to it? Looks like there's a torx screw right next to where the lighter is....
TIA
Old Apr 13, 2009 | 07:51 AM
Shylor's Avatar
Shylor
I have taken mine apart several times but each time that outlet plug doesn't connect properly when I reinstall the console, so it doesn't get any power to work. I am at my wits end.
Old Apr 13, 2009 | 09:46 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
did your fuse blow?
Old Apr 13, 2009 | 09:48 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
TIA
you'll have to take the radio bezel out to get to the back side of the lighter. to get to that, you'll have to slide the center console back and remove the traction control plastic piece. then you have 2 screws in the ashtray area, and 1 behind the temp sensor near the ignition.
Old Apr 13, 2009 | 12:59 PM
TPA Z06's Avatar
TPA Z06
That's kind of what I figured, having to basically disassemble the entire area just to get to it. It's almost the same drill as installing an aftermarket shifter......
Old Apr 13, 2009 | 05:21 PM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
yeah, but it's pretty quick and easy to do. I can get my radio bezel out in 5 minutes.
Old Apr 14, 2009 | 06:36 PM
Shylor's Avatar
Shylor
did your fuse blow?
No it did not.
Old Apr 15, 2009 | 12:38 AM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
TIA
The screw next to the lighter is one of many holding in the console, another hidden behind ash tray.
To Cigarette lighter?
