New tire pressure
Old Apr 14, 2009 | 05:16 PM
tramminc's Avatar
tramminc
Default New tire pressure
New tires are 275/35-18 and 335/30-19, the old tires were set at 30 lbs all around. I think the front should stay the same and maybe the rears raised to 33 - 35 lbs, because 30 may be under inflated.
What are you guys with 335 or 345 running?
Old Apr 15, 2009 | 03:24 PM
tramminc's Avatar
tramminc
tough crowd, I quest I'll have to answer my own question. Today I called Nitto, their tech' stated that the rear tire (335/30-19) should be set at 30lbs.He used his chart and based it on the load each tire can carrie. the 295/35/18 are 93Y, 355's are rated at 103W which has a larger load capacity. And sence the cars weight is less than 3,500lbs, 30lbs is normal.
I had it set at 33 for better side wall profromance, but I quest I'll reduce it later.
Old Apr 15, 2009 | 04:35 PM
poolboy's Avatar
poolboy
for the most part 30 psi cold should work, although you may want to watch them over time for wear, and adjust up or down as required
To New tire pressure
