Quick tire size question
Old Apr 15, 2009 | 02:26 AM
kevin40zx's Avatar
kevin40zx
Default Quick tire size question
I'm getting wider rims in the front (17/ 9.5) as apposed to stock (17/8.5). I want a wider tire with correct sidewall hight to not throw off the speedometer. What do you guys recommend? I was thinking 255/40 or 255/45?
Old Apr 15, 2009 | 09:53 AM
RAL04VETTE's Avatar
RAL04VETTE
You can use this site to calculate outside diameter tire size.
http://www.rims-n-tires.com/rt_specs.jsp
Old Apr 15, 2009 | 11:49 AM
Gideon's_Test's Avatar
Gideon's_Test
Or...http://www.miata.net/garage/tirecalc.html
Old Apr 15, 2009 | 12:55 PM
kevin40zx's Avatar
kevin40zx
That answers my question.
Thanks to you both.
Old Apr 15, 2009 | 03:02 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Which tires are you going with? Your only telling us half of a story! LOL
Old Apr 15, 2009 | 03:23 PM
knyght4's Avatar
knyght4
To my belief, the front tires size WON'T throw the speedo off - the rear tires will.
Old Apr 15, 2009 | 04:17 PM
Bill Dearborn's Avatar
Bill Dearborn
You need to ensure the new front tire diameter remains at least a half inch smaller than the rear tire diameter. Other than that choose a profile that fits the rim. If you get the front diameter too large then the traction control will activate while you are driving.
A 255/45/17 will have a diameter of about 26.1 inches (varies slightly with mfg). The stock rear diameter is 26.8 inches so you should be OK with the sizes you stated.
Bill
Old Apr 15, 2009 | 04:41 PM
Russ K's Avatar
Russ K
I would use a 265/40/17 on the front.
Russ Kemp
Old Apr 15, 2009 | 06:07 PM
kevin40zx's Avatar
kevin40zx
Just street tires. Havn't decided which ones yet but I'll probably go with something cheap. I just put some sumitumo HTR III's on the back wheels (stock sizes) about two months ago. They are good so far. Really cheap on tire rack too. But I just bought some OE Wheels deep dish C6 Z06 replicas that are wider and figured I could get some more rubber on them for performance and looks.
I'll probably go with the 255/45/17. If I get wider tires on the back next tire change I will definetly go with the 265/40s.
To Quick tire size question
