Damper/pulley problem
Old Apr 15, 2009 | 12:06 PM
baezi z06's Avatar
baezi z06
Default Damper/pulley problem
Hello i´m new here
i got 2004 Z06
whith Trickflow heads and Comp cam 281/283 232/234 .595/.598 112 LS,
my orginal damper keeps running loose , though i´ve tried tvice to install it whith glue on the bolt.
Why does this happen?
I goin to buy new one, but i´m not sure which damper is the best for my vette, for best performance and on good price.
What do you recomend?
Old Apr 15, 2009 | 12:39 PM
lucky131969's Avatar
lucky131969
Originally Posted by baezi z06
Hello i´m new here
i got 2004 Z06
Did you use Elmer's wood glue? That seems to work the best for the balancer bolt....... Just kidding.....sorry, I digress.
If you've gummed up that bolt with glue, I'd get it out of there, and chase the crank threads to get everything cleaned up.
Get a new bolt, whether GM or ARP. Follow the service manual procedure to the letter for torquing, and you will be fine. Depending how long this has been going on, I assume you'll replace the balancer, and might as well do the oil seal.
Old Apr 15, 2009 | 01:32 PM
baezi z06's Avatar
baezi z06
which one is the best to buy, whith performance and prize in mind.....?
Old Apr 15, 2009 | 03:21 PM
timemender's Avatar
timemender
Here’s what I’ve installed on a friend’s C5 LS1 – The Summit Damper is very well made & has a reasonable price.
Also check out the damper holding/rotating tool – I haven’t used this tool – just ran across it in the catalog.
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/partde...8&autoview=sku
EDIT - Install instructions PDF below:
http://static.summitracing.com/globa...ions%20rev.pdf
Old Apr 15, 2009 | 03:28 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
The SLP UD Pulley is a nice piece. We keep them in stock. It comes with a new GM Crank Bolt and we can get you the proper Serpentine belt you'll need as well.
$179.95 - SLP Underdrive Pulley
Old Apr 15, 2009 | 03:36 PM
baezi z06's Avatar
baezi z06
ok thanks
how is the SLP pulley whith belt compare to the ASP whith belt? price and performance... ?
Old Apr 15, 2009 | 03:40 PM
timemender's Avatar
timemender
Nice product from the description. I like the high retaining walls.
Many have installed an under drive pulley and have been happy. I stayed with the stock size as I feel the five HP gain isn’t worth any potential issues.
Old Apr 15, 2009 | 03:46 PM
0HinsonSuperCars
Former Vendor
ok thanks
We have used both and both work great. You cannot beat the SLP unit for that price and it has higher walls to help against belt slip.
Old Apr 16, 2009 | 09:04 AM
baezi z06's Avatar
baezi z06
should i talk direct to you if i wante to order the SLP damper....
i sent you email and PM
kv Baering
Old Apr 16, 2009 | 10:48 AM
0HinsonSuperCars
Former Vendor
kv Baering
Email and PM sent.
To Damper/pulley problem
