Service ABS started flashing
Old Feb 1, 2002 | 08:03 AM
tonyh2000's Avatar
tonyh2000
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03
Default Service ABS started flashing
Yesterday the D.I.C. started flashing service abs, service active handeling, service traction control. I stopped the car and turned the car off and removed the key and waited a few sec. and restarted the car and everything was OK. Then again this morning same thing, but this time I had to shut the car off twice before it would clear.
Has anyone else had this problem and if so did it require a trip to the dealership?
[Modified by tonyh2000, 7:31 AM 2/1/2002]
Old Feb 1, 2002 | 08:15 AM
VettTheRipper's Avatar
VettTheRipper
Default Re: Service ABS started flashing (tonyh2000)
The very first thing you should do is check your brake fluid level. If it is at the full mark then you should take it in.
Old Feb 3, 2002 | 02:07 AM
barryscott's Avatar
barryscott
Hey Now:
First thing you need to do,is pull your codes and see what is going on. :yesnod:
Old Feb 3, 2002 | 02:51 AM
cosmo's Avatar
cosmo
I got the same problem. It is very anoying.
Do you have Russell SS break lines by any chance?
A few other people got the same messages and they think is the SS lines.
My code is C1226. What code do you get?
My car is going to the dealer in the next two weeks sometime. I will ask them to change the speed sensor on the front left wheel.
I already change the wire harnes for the sensor (somebody else got his problem fixed this way), but it did not work for me. Still getting the codes.
To Service ABS started flashing
