car electric volts flicker
Old Apr 17, 2009 | 09:17 PM
shihiran's Avatar
shihiran
Default car electric volts flicker
why do my 98 vet electric system flickers when i push the driver side window down or up?
It is like when i am just idleing i heard to fuel pump flickering along with the radio,havc and the headlights.like when i push the window button every thing just flick for a second.
Old Apr 17, 2009 | 09:28 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Probably time to check your battery connections as well as the battery to starter connection to insure they are clean and tight. How old is the battery?
Old Apr 17, 2009 | 10:00 PM
shihiran's Avatar
shihiran
battery is no more than year old.
Old Apr 17, 2009 | 11:14 PM
dgrant3830's Avatar
dgrant3830
The window motor is a high-current draw item which is why I was asking about the battery. You might want to have the battery load tested just in case. Is it only one window that is causing this?
Old Apr 23, 2009 | 08:00 PM
shihiran's Avatar
shihiran
this is what it is doing. its like when the window is down when you push the up button it draw a big current and my havc dim along with my radio. you can also hear the relay fuse on the passenger side.
Old Apr 24, 2009 | 12:03 AM
dgrant3830's Avatar
dgrant3830
Does the window appear to come up at a normal speed when compared to the other side? Does the other side cause the same thing to happen with the massive current draw?
To car electric volts flicker
