ABS & Active Handling Lights
Old Apr 18, 2009 | 06:09 PM
OLD BROWNIE's Avatar
OLD BROWNIE
Default ABS & Active Handling Lights
Wife's 2002 has 44,000 miles & original brake pads and both the ABS & Active Handling lights came on. I pulled front wheels & both of the inside pads of each wheel had worn more than the outside pads. I only had time to replace all front pads but the ABS & Active Handling lights are still on after a test drive. I haven't looked at the rear wheel brake pads so I don't know how bad they are. Do I need to reset something, unplug and replug the sensor at the wheel or what to get the lights to go off. Or, are the rear wheels telling me they need new pads also ?. Any advise on how to get the lights to go off ?. You can email if you want at Ronfjd@msn.com and thanks in advance. RD
Old Apr 18, 2009 | 06:18 PM
87SAM's Avatar
87SAM
Probably has nothing to do with the pads, need to check the DTC for codes.
Old Apr 18, 2009 | 07:49 PM
byronhunter's Avatar
byronhunter
Read Trouble Codes and post them.
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Old Apr 19, 2009 | 09:31 AM
jkz06's Avatar
jkz06
Originally Posted by byronhunter
. The code should tell you exactly where the problem is. I just finished pulling the rear subframe, rear end and tranny out of my car about a month ago and everything was fine but after a few miles I got the same message. Pulled the code and it told me it was a short in the right rear sensor. Looked at it and the rim had rubbed the wire through. Being able to check codes on our cars is awesome.
Old Apr 20, 2009 | 07:22 PM
Vett Time's Avatar
Vett Time
Would this be the same diagnostic for 1999. If not do you have it.Thanks
Old Apr 21, 2009 | 11:51 AM
jkz06's Avatar
jkz06
I don't remember the exact code number but I think all C5's the diagnostic ability. Just go off the link above and it should walk you through it. If you need help post the code number and we can go from there.
To ABS & Active Handling Lights
