Windows not going down issues
Old Apr 18, 2009 | 09:09 PM
maddogcharlie200's Avatar
maddogcharlie200
Default Windows not going down issues
I can't seem to find too much information about this issue. Except, hit the door panels and push the switch. Without all of the guess work, whats really going on and what is the solution.
Old Apr 19, 2009 | 05:27 AM
urfubar's Avatar
urfubar
Here is the best info on your problem...start small and work your way up approach.
http://forums.corvetteforum.com/c5-t...cs-inside.html
Let us know what works.
Old Apr 19, 2009 | 08:58 AM
maddogcharlie200
Thanks Urfubar, this type of information is greatly appreciated.
Old Apr 19, 2009 | 03:48 PM
maddogcharlie200
If the connector is bad, will you still hear a click coming from inside the door panel once the window switch is depressed ? If you hear a click, would that mean a poor connect to the motor or a bad motor ?
To Windows not going down issues
