A/C comp leaking oil ??
Old Apr 19, 2009 | 11:21 AM
Sting99's Avatar
Sting99
Default A/C comp leaking oil ??
The car has been sitting in the garage for about 3 weeks , when I backed her out this morning found a little oil on the floor , it looks like its from the A/C , everything works fine and the air is cold. any ideas are the seals probably going ??? any advise would be greatly appreciated
Old Apr 19, 2009 | 11:41 AM
skinny1's Avatar
skinny1
My AC compressor did the samething. It was leaking around the seals. I had to have it replaced.
Skinny
Old Apr 19, 2009 | 11:46 AM
Sting99's Avatar
Sting99
I also hoping for some quick fix !!!! , so I guess when I replace the comp , it is also recommened to do the dryer ??
Old Apr 19, 2009 | 12:32 PM
lucky131969's Avatar
lucky131969
Do some more careful inspection. I've seen compressor seep, but never leak to where there is a puddle on the floor(especially and still hold a charge)
Old Apr 19, 2009 | 08:42 PM
Sting99's Avatar
Sting99
I haven't been able to get under the car , but the leak on the floor was the size of a Dime. I will see if I can get under there this week and check it out , since it's not a DD.
Old Apr 20, 2009 | 01:26 AM
PierEagle's Avatar
PierEagle
Had the same. Small spot on driveway. Look on top of the frame directly below the compressor. If it is all wet, you have a compressor leak. I had one. Recharged the system 2 or 3 times over a 3-4 month period. Finally bit the bullet and had the compressor replaced (thanks ANTHONY01). No mo problem.
Old Apr 20, 2009 | 08:19 AM
FL_Dave's Avatar
FL_Dave
Default Just do the seals
I may have experienced the same thing - one or both of the seals on the rear "lineset" went out. If so, the fix can be cheap, somewhat easy, and reliable. Here's the link (with pictures) if you are a DIYer and interested: http://forums.corvetteforum.com/c5-t...ng-advice.html
Dave
Old Apr 20, 2009 | 09:23 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
A compressor will usually start seeping only around the shaft seal, and then you will notice just an oily residue around the compressor clutch and pulley.
It's VERY unlikely that the puddle on the floor came from your A/C compressor. There's only a few ounces of oil in it.
Old Apr 20, 2009 | 09:34 PM
Sting99's Avatar
Sting99
Dave
Dave , thanks for the info and the pic's are a major bonus !!!!! , it's just like you stated , I will try to tackle it this weekend !!!! This forum is awsome .... hopefully someday I can pass it on..
To A/C comp leaking oil ??
