Part number help
Old Apr 19, 2009 | 06:59 PM
squidwards vert's Avatar
squidwards vert
Default Part number help
On the clutch master, this part is held in at the bottom of the master with a dowel pin, and runs to the slave connection. The white plastic seal where it connects to the slave is broken so no pressure will build.
I can't find the part anywhere.
Can someone help?
thanks
Old Apr 20, 2009 | 05:12 PM
squidwards vert
bump.
Really need some help please, TIA
Old Apr 20, 2009 | 05:40 PM
MattB's Avatar
MattB
I'd call www.gmpartshouse.com and see if they can help. However, I do not think that the hose is a seperate part from the master cylinder. The copy of the GM parts manual I have does not list a part number for it, only for the master.
Old Apr 22, 2009 | 09:59 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks for the referral. Your answer is correct.
To Part number help
