DIC warning 1999 vert
Old Apr 20, 2009 | 06:44 PM
Vett Time's Avatar
Vett Time
Default DIC warning 1999 vert
My Dic every now and then tells me to check active handling and ABS.When it comes on, I pull over to the side of the road, shut the car off, start it again and that clears the DIC for a time...???? HELP
Old Apr 20, 2009 | 07:52 PM
buoniconti81's Avatar
buoniconti81
I cleaned my ground points and it went away.... check out the ground point cleaning procedure at the top...
Old Apr 20, 2009 | 09:27 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You need to pull the codes
To DIC warning 1999 vert
