Final answer on LS7 preload please
Old Apr 21, 2009 | 03:04 PM
OhioC5's Avatar
OhioC5
Default Final answer on LS7 preload please
I know its beat to death, but there is so much debate on LS7 lifter preload. I would like to hear from a legit engine builder or vendor please. I measured my push rods today.
Length checker is 6.8" closed
I turned it out 12 times to match my 7.4 push rods.
Closed it down two turns. (7.30") perfect
10 turns to close = .500 6.8+.500=7.300 .100 preload is 7.400
Is .100 good for a street car? I drive it on the weekends and track it about 3 times a year. I've read .050-.080-.100, is there no real answer?
1997 Corvette
GM 5.3 heads bronze guides
Comp cam 228/232 .588 .592
Old Apr 22, 2009 | 02:01 PM
fst85vtt's Avatar
fst85vtt
wow no I know it all answers?
I researched the hell out of this and I ended up going with .058 using a 7.350 hope this helps
Old Jun 20, 2009 | 12:09 AM
Mike94ZLT1's Avatar
Mike94ZLT1
I would REALLY like to know this as well!
Old Jun 20, 2009 | 07:24 AM
dougbfresh's Avatar
dougbfresh
HP TV did a thing on this a week or so ago (on an LSx engine). You get and adjustable pushrod and some machine bluing. Use the bluing on the top of the valve, set to 0 lash, spin the engine a revolution or 2 by hand and examine the top of the valve to see how the rocker is hitting it. Should be RIGHT IN THE MIDDLE of the valve-readjust the pushrod and relash till you get the rocker hitting the valve correctly.
Old Jun 20, 2009 | 10:06 AM
NassyVette's Avatar
NassyVette
You are refering to the wipe pattern, which is affected by the rocker height. On stock rockers anything over .550 lift subjects the valve guides to abnormal stress. You can get away with it on stock guides, but it seems to wear bronze guides out prematurely. The best solution in that case is a roller tip rocker.
As far as the proper preload on the LS7 lifters, I hope its .070 because thats what I set mine at. I would think on a street car that stays at lower RPMs a little tighter would be OK. And an engine that sees 7000rpms a little looser is ok. I'll report back if my lifters fail
Old Jun 20, 2009 | 10:45 AM
tsts's Avatar
tsts
???! Not the answer to the question.
NassyVette - I am facing the same issue next week (23rd) with new Harland Sharps roller tips and don't have an answer, I'm running a little more lift than you. Going to go with .035 (+-) preload for a PR length of approx. 7.3 unless you or someone else has a pretty good idea what it should be. Using stock 7.4's now and think it is too much. If you get an answer from someone that knows their stuff, please post ASAP. Thanks.
Old Jun 27, 2009 | 05:28 PM
tsts's Avatar
tsts
6/27/2009
OhioC5 & NassyVette - At ECS (John) this past week, when John measured for pushrod length, he found that 7.35 pushrods gave me the preload I was looking for, the valve train noise is actually a little quieter than it was with stock LS1/7.4 pushrods, performance still as good. It does seem that using an LS7 lifter does require a shorter pushrod, even in my application (GM block, LS7/427).
To Final answer on LS7 preload please
