Problems with tracing ...Horn
Old Apr 22, 2009 | 08:57 AM
kg54trains's Avatar
kg54trains
Default Problems with tracing ...Horn
98 Coupe
having checked the fuses and about to check the voltage at the connections of the horn's leads, would the only other problem be with the horns and the horn switch in the sterring wheels air bag??????
Old Apr 22, 2009 | 10:46 AM
byronhunter's Avatar
byronhunter
This might help.
Old Apr 22, 2009 | 10:56 AM
slothy's Avatar
slothy
u can get to the horns from trim panel under passenger side of the front bumper to test.
Old May 27, 2010 | 02:08 PM
ldonnel's Avatar
ldonnel
5th Gear
Try taking the cover off of the fuse panel under the hood, and listen for the relay to
click when you push the horn button. If it clicks it is probably a bad relay-easily replaced. That is what was wrong with my 2000 vert. The horn would work intermittenly, actually it rarely worked. A new relay costs around 16 bucks from Oreillys-apretty cheap fix.
Old May 27, 2010 | 03:59 PM
AMooreesq's Avatar
AMooreesq
Navigator
Originally Posted by byronhunter
This might help.
Didn't I just see your cars in a corvette magazine this month?
Old May 28, 2010 | 12:05 AM
byronhunter
NO, not that I'm aware of.
To Problems with tracing ...Horn
