MSD window switch ?
Old Feb 2, 2002 | 12:40 AM
Skeeter1's Avatar
Skeeter1
Default MSD window switch ?
Does the MSD window switch need to be "calibrated" to work on a c-5 ? a local shop is telling me they have to send it to MSD to get it "callibrated before it will work, another shop who installs a lot of these on c-5s and f-bodys says no, what gives ? :confused:
Old Feb 2, 2002 | 01:02 AM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: MSD window switch ? (Skeeter1)
Nope, just snip the two loops, install the pills you want, hook it to the PCM, and you're ready to rock!
Old Feb 2, 2002 | 01:52 AM
ICULUKN-C5's Avatar
ICULUKN-C5
No the MSD does not have to be calibrated. Use it in 4 cyl mode. Reasoning behind it is that the white wire on the ECU controls 4 cyls. Unlike the mustang that had 8 ECU wires (one for every Cyl), we only have 2 ( one for each side). If you have any more questions feel free to email me..
Old Feb 2, 2002 | 04:50 AM
jetskifast's Avatar
jetskifast
Cut both wires as 4 cylinder. Hook tac wire to pin #10 white wire on your PCM.
To MSD window switch ?
