axle seals might not be a bad idea. Theyre easy to do while its all out. May also consider torque tube bushings, not quite as easy as the seals however....
I believe that I will doing halfshafts in the very near future so I'll probably wait until then....good thinkin! Thanks
That brings up a good topic...What sway bar and shocks are you running?
I will be at the drag strip and motoring around town
I still have stock on myself, but when i do my H/C I will problably go with C6 Z06 shocks and the C5Z06 sways with metal endlinks. I have heard a lot of good things about that combo. Not too stiff of a sway bar, but makes the car feel much better than stock.
