has anyone tried a cam setup like this
Old Apr 23, 2009 | 06:59 PM
huttler's Avatar
huttler
Default has anyone tried a cam setup like this
Currently I have a compcams 224/228, .581/.588,and LSA 114. I'm thinking of getting another cam that's almost identical but with an LSA of 118. This way I'm hoping I can pass emissions (recently moved) but not sacrifice any hp. With the 114 LSA there is -2 degrees of overlap, -10 with the 118 LSA. The factory ls1 cam has something around -30 so I don't know if this will be enough to pass emissions or not.
Old Apr 23, 2009 | 07:25 PM
zeevette's Avatar
zeevette
Have you tried to pass the test with your present cam? The reason I ask, is on several older discussions of cam choice/CA. emissions testing, the 224/228@114 was touted as about as big a cam that'd pass.
Old Apr 23, 2009 | 08:02 PM
huttler's Avatar
huttler
It passed at the 2500 rpm (barely) test but failed at idle (950rpm). The maxium allowed idle is 1000 rpm. Even with the idle that high it was well over the limit, gross polluter! lol
Old Apr 23, 2009 | 09:31 PM
bcseitz's Avatar
bcseitz
Have you talked to a reputable tuner about it? Idle trims, (RAF, MAF, VE) could be a tad rich and leaned out to work just fine. Should idle fine at 900 or less.
With that cam, idle cells could be a little leaner than stoich anyway using 27-28 degrees of advance.
Good luck!
Bob
Old Apr 23, 2009 | 09:57 PM
huttler's Avatar
huttler
I was trying to avoid the $$$ for a tuner again but maybe that's the only option left.
what about changing the cam to a 118 LSA, i've been thinking about putting on some Patriot LS2 ported heads and doing the cam swap at that time if it would help
Old Apr 23, 2009 | 11:52 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I have a similar cam @ a 114 LSA ( and passed easily)---I believe that as long as you don't go lower than a 114 you'll be OK---I've rarely seen a 112 pass in Calif---If you have LT headers then that is most likely why you are over on the HC numbers----The cats take care of the NOX numbers generally----LT's make your closed loop fueling way rich because of the 02 bung locatons making the commanded AFR of 14.68 more like 12.0--so rich that the HC go crazy------
Old Apr 24, 2009 | 12:15 AM
bcseitz's Avatar
bcseitz
Cam plus heads, parts, labor AND a new tune will cost even more and net not that much more HP!
If you must, a small blower cam with a supercharger will make a bunch more fun factor for the money and you will be emissions compliant too.
Just my .02
Old Apr 24, 2009 | 01:39 AM
C5 LS7's Avatar
C5 LS7
The secret is fresh cats!!! I passed the CA. sniffer running 230/240 -629/649-112 lsa in a 442 LS7 C5. New cats clean up A LOT of smog. replace the cats w/ new hiflow units and I bet you pass.
Old Apr 24, 2009 | 11:22 AM
Uncle John's Avatar
Uncle John
114 to 118 is going to drop your DCR about .3 points and put you Intake Valve Closing at 50* ABDC.
Old Apr 24, 2009 | 11:43 AM
sami85L98's Avatar
sami85L98
Looks like u r a good candidate for LG G5x1-E cam, or Lpe GT2-3 Cam.
I used to live in GA, and i passed my C4 with similer cam but it was close call tho.
Old Apr 24, 2009 | 08:33 PM
huttler's Avatar
huttler
thanks for all the help, I"m taking my car to the tuner and taking a look at the cats
To has anyone tried a cam setup like this
