Tstat Housing torque spec
Old Apr 24, 2009 | 09:53 AM
twold's Avatar
twold
Default Tstat Housing torque spec
I'm replacing my T-Stat and want to know what the torque setting is on the bolts that hold the T-Stat in. I couldn't find it anywhere.
Old Apr 24, 2009 | 10:26 AM
slothy's Avatar
slothy
i believe they are 11ft lbs, ill try and double check when i get home.
Old Apr 24, 2009 | 11:00 AM
87SAM's Avatar
87SAM
From the 98 manual:
Tighten the thermostat housing bolts to 10 N·m (89 lb in).
Old Apr 24, 2009 | 11:04 AM
sami85L98's Avatar
sami85L98
I just did installed last weekend 160 stat, and i tightened with finger and than just 1/2 turn with the wrench, no leaks after 100 miles sofar. Make sure u apply a very very light coating of RTV silicone to O ring otherwise it might pinch. I used old O ring new one was questionable.
To Tstat Housing torque spec
