headlamp motor
Old Apr 27, 2009 | 11:47 AM
MY 2000's Avatar
MY 2000
Default headlamp motor
hello all would anyone have pictures or a good description on how to remove a r/s headlamp motor do you have to take the headlamp assy. out. thanks
Old Apr 27, 2009 | 01:01 PM
timemender's Avatar
timemender
Searching this forum found these threads -
http://www.rodneydickman.com/n113.html
http://forums.corvetteforum.com/c5-g...orialized.html
http://forums.corvetteforum.com/c5-g...-gear-fix.html
http://www.top-downsolutions.com/pro...products_id=87
Old Apr 27, 2009 | 03:51 PM
Oldvetter's Avatar
Oldvetter
Make sure your motor is bad, usually only the plastic gears go bad and cause a "machine gun-like" noise (eventually), but early on the headlight just won't come up.
Old Apr 27, 2009 | 04:19 PM
Rickyh93's Avatar
Rickyh93
I didn't take mine out but it would have been alot easier to do that. My arms aren't that small and I must have dropped my ratcheting wrench 4 or 5 times into the bumper area and a couple of the nuts the same amount. Thank goodness for telescoping magnets.
To headlamp motor
